Hi there,
I found a very helpful description of Mark Nicholson on “How to model a black-box optical system using Zernike coefficients”.
When I start calculating Huygens PSF in that paraxial equivalent model, I see some deviations to the real system (especially when I go to large field angles).
Why and what should I consider to make Huygens PSF work “correctly” in that case? Any ideas?
Kind regards!
Be the first to reply!
