"Ray Splitting" vs "Split NSC Rays"
  • February 14, 2025
  • 73 views
mocquin
The doc defines “Ray Splitting” at “The Setup Tab > Editors Group (Setup Tab) > Non-sequential Component Editor > Non-sequential Overview > Ray Splitting”
and mentions “Ray splitting can be turned off”.
Can you confirm that “Ray splitting” always refers to “Split NSC Rays” in the Ray Trace Control and 3D layouts ? I mean using precise vocabulary would minimize confusion
Best answer by Ray
Hi Mocquin,
As the words “ray” and “split” are the same in both expressions, I assume the “NSC” is what you find confusing: It means “Non-Sequential Component”. I guess it was too long to write fully (this dialog dates back from the early 2000s, when screens were much smaller). Perhaps “Non-Sequential” would be better.
If you refer to the “Split” vs “Splitting”, it looks consistent with usual standards:
“Ray splitting” in the documentation is a topic, for which a name form is a common way (see the other sections of the documentation, most are in nominal form, “Editors Group”, “The Setup Tab”).
“Split Rays” is using a verbal form because that is the standard in graphical user interfaces (“Save Rays”, “Use Polarization”, “Trace”, “Clear”, “Exit” but also in the older “File”, “Edit”, “Format” menus)
  • 109 replies
  • February 14, 2025
Hi Mocquin,
mocquin
  • 38 replies
  • February 14, 2025
Thanks, I understand the rationale of using verbal all throuhgout the GUI
Sean Turner
  • 101 replies
  • February 14, 2025
The help file says this in The Analyze Tab (non-sequential ui mode) » Trace Rays Group » Ray Trace:
Split NSC Rays If checked, rays will split according to the interface properties as described in "Ray splitting".
