TIR (total internal reflection) error during the lens optimization popping up
  • November 6, 2024
  • 184 views
pepe
Hello, I use OpticStudio 15.5 SP3 and I have an issue with optimizing the design consisting of “of the shelf” components by Thorlabs, reflective collimator, and objective lens. I want to obtain the image in focus, but I get the error stating: Error in target 5. TIR at surface 7!
Possible reason for this behaviour is negative thicknesses: 1. in collimator in order to get the rays reflecting of the mirror, and 2. in lens in order to make the rays go through the lens. If I change the thickness following the reflective collimator to positive (-100 to 100) then the rays reflect inwards. If I change the thicknesses of lens and air after lens from negative to positive, the rays are reflected from back surface of the lens.
How do I run optimization without error?
Yang.Yongtao
  • 65 replies
  • November 7, 2024
how about optimizing the system from object NA 0.1→0.12→…0.16?
pepe
  • November 7, 2024
@Yang.Yongtao I understand that beam diameter is larger than lens diameter, but the light source has numerical aperture of 0.16. That’s why I didn’t change it. It appears that  if I change Criteria from Spot Radius to Wavefront in Optimization wizard the system can be optimized. The same is true if I insert a lens of greater diameter than the light beam diameter. I don’t understand why, but at least I get some results.
