Concave mirror lens system design and reservation of field of View ?
  • October 16, 2024
  • 174 views
OpticalResearch
Not quite sure this community is still active?
I want to have a lens system which can form the image from infinity to a limited distance as show below.  As you can see that the concave lens system will reduce the input field of view.  How can I have a compact concave lens system which can form the image from infinity to a limited distance and keep the same field of view as the input.  Can you have some suggestions or initial configuration for recommendation?
Thank you !
BL
Michael.Young
  • 42 replies
  • October 18, 2024
Hello @OpticalResearch,
As I understand your problem statement, you want to create an eyepiece that forms a virtual image of an object at infinity. This eyepiece also needs to satisfy some field-of-view requirement (that you describe as input). To set this up in Zemax, you can describe the EPD or float by stop size. The latter may be simpler but you’ll need to enable ray-tracing. The stop could be the aperture of the eye. You would then define wavelength, and the fields.
You can introduce a lens between the object and the stop. This could be a singlet, doublet, compound lens etc. Its clear aperture needs to satisfy your FOV requirements. The distance between the lens and the stop will need to be defined by you. For eyepieces, this is referred to as eye-relief or even more generally as an eye box.
To introduce the virtual image, trace the rays “backwards” from the stop to the image, i.e, a negative thickness. Again, you’ll have to specify the desired value to the virtual image.
I hope this helps.
OpticalResearch
  • 10 replies
  • March 27, 2025
Hi Michael,
Thank you very much for the good advice about that. I had a try of this. However, I found that the thickness of lens element is hard to controlled within a thin size, especially when the eye relief is large.  Do you have any further comments on this?  Appreciated !
BL
