I was eager to try out this new feature in 2024 R2.02, but I don’t think it’s working properly. I tried exporting a simple file, one OAP mirror with 9 fields defined. When opening the file in SpaceClaim, I did not see any ray footprints on the mirror. I tried all 4 file type options, and none seem to do what I would expect. Can somebody explain the intended workflow and outcome here?
Sean
