Optimize placement of Aperture
Olieli
I have a complex laser delivery system, with several lenses, that ultimately is a 1:1 for an array of lasers (modeled as different fields).
There is a physical aperture inside the system (for straylight purposes).
I’m trying to optimize it’s Z placement so that it’s located at a point where the combined spot size of all fields is minimal.
I’m not finding a simple way to do this in Sequential - although I assume there must be.
Any insight?
Thank you!
Best answer by Jeff.Wilde
I suggest you try using the extended source encircled energy feature.  First, create a simple IMA file that represents your laser source array (e.g., an array of ones embedded in a background of zeros).  Check it using the Extended Source Encircled Energy tool in the GUI, or the Geometric Image Analysis tool.  In this case you would most likely just use Field 1 for purposes of locating the IMA file center.  If satisfied with the results, then simply use the XENC operand for optimization purposes.
Olieli
  • 10 replies
  • June 5, 2024
Each color is a different Field. I’m trying to optimize for the Z of that (orange) surface.
Yang.Yongtao
  • 65 replies
  • June 6, 2024
Hi Olieli
 Footprint may help?
 the question changes to how to get the footprint size in merit operand
Yang
Yang.Yongtao
  • 65 replies
  • June 6, 2024
Yang.Yongtao wrote:
Hi Olieli
 Footprint may help?
Yang
or ray height on the aperture surface (Max REAY-Min REAY)?
Olieli
  • 10 replies
  • June 6, 2024
Hi Yang and thank you for your reply.
I’m not sure how that helps...
  • 510 replies
  • June 7, 2024
