IMA File viewer
Hi all.
I discovered something strange during geometric image simulation.
When I open the .IMA file in Notepad, I can see that it matches the .BMP file.
However, when I check it in the IMA file viewer, some parts are cut off and a discontinuous line pattern is visible. This also leads to strange results in geometric image simulations.
.BMP file
part of the .IMA file
.IMA image with IMA viewer
How can I fix it?
I uploaded .IMA and .BMP files.
I'm asking for help.
Thanks.
Be the first to reply!
