Missing pick up solver in thickness and radius column
  • April 2, 2024
  • 184 views
Hello
After update to latest version, the ‘pick-up’ solver in thickness and radius column were disappeared. Does it happen on my machine only?
Best answer by Kevin Scales
This bug has been spotted and filed with urgency. It is not just on your computer. It looks like existing files with the missing solves can be read and run, but the dropdown is not functioning. The developers are currently aware of this issue. We do apologize for the inconvenience this is causing.
Kevin Scales
  • 185 replies
  • April 2, 2024
