I am Attempting to export a Non sequential design in a STEP format. I would also like to export the ray.
Problem is that when I open the CAD files export the folowing options are grayed out:
-Number of rays: grayed and fixed to the value 0
-Ray Pattern, grayed and fixed on the option XY fan
-Angular tolerance grayed and fixed on low
-Box Delete vigetted grayed and fixed on checked
With these options not accessible I cannot produce a reasonable STEP file. Previously I have done it without problems.
Someone has an idea about?
Thanks
Best regards
Best answer by Akhil Dutt Vijayakumar
Thank you for posting in the forum.
In the non-sequential design, the number of rays cannot be changed in the same way as the sequential CAD export. To add rays, you can change the number of layouts rays before you export your design. I can show you an example of cook 40-degree field in non-sequential mode for easy understanding.
Here I have taken different number of layout rays for each source. Then the exported CAD design(step file) is opened in SPEOS. (see attached images)
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
