Multi-configuration operand for ignoring a range of field numbers
  • February 16, 2024
  • 175 views
i need to ignore a range of fields in a multi-configuration system. is there something similar to IGNM operand which ignores a range  of surfaces.
thank you
aalim
@aalim
Put the Field Weight to zero with the Multi-Configuration operand FLWT.
  • 1130 replies
  • February 16, 2024
@aalim
