Answer
Zemax equivalent to Code V Anamorphic Asphere surface?
  • January 4, 2024
  • 198 views
Mike.Jones
As far as I can tell, the Zemax Biconic Zernike surface is NOT defined in the same way as the Code V Anamorphic Asphere.  The Code V conic portion is the same as the Zemax Biconic surface.  However, the Code V aspheric terms are defined differently:
sag z = (Zemax or Code V biconic formula)  +
​​​​​​​AR{ (1 - AP)x^2 + (1 + AP)y^2 }^2 ​+ BR{ (1 - BP)x^2 + (1 + BP)y^2 }^3 +
CR{ (1 - CP)x^2 + (1 + CP)y^2 }^4 ​+ DR{ (1 - DP)x^2 + (1 + DP)y^2 }^5
where
AR, BR, CR, DR are the rotationally symmetric portions of the 4th, 6th, 8th and 10th order deformation from the conic, and
AP, BP, CP, DP are the non-rotationally symmetric components of the 4th, 6th, 8th and 10th order deformation from the conic.
So my question is:
  1. Is there a macro available to translate a Code V anamorphic asphere surface into a Zemax Biconic Zernike surface?
  2. Or, is there a Zemax DLL that emulates the Code V anamorphic asphere?
Thanks, Mike
Best answer by Mark.Nicholson
Try the Composite Surface feature. If we’d done it that way in the beginning there would be maybe 10 surface types today :-)
But to your questions, (1) I’m not aware of such a macro and (2) sure a DLL can do anything so it’s a great way to define a surface that isn’t natively supported. But the Composite Surface is better.
  • Mark
  • Mark
