Answer
Laser Source Modeling
  • December 29, 2023
  • 346 views
Seyoung Kim
I am comparing the linked materials attached below.
https://support.zemax.com/hc/en-us/articles/1500005490261-How-to-model-laser-beam-propagation-in-OpticStudio-Part-1-Gaussian-beam-theory-and-ray-based-approach
https://support.zemax.com/hc/en-us/articles/1500005578582-How-to-model-laser-beam-propagation-in-OpticStudio-Part-2-Using-Paraxial-Gaussian-Beam-analysis-to-model-Gaussian-beam
I think the biggest setting difference between the two materials is Object Surface Thickness. So I am comparing the following two cases.
Case 1
  1. Surf #0 Thickness = 0
  2. Surf #1 Thickness = 20
  3.
Case 2
  1. Surf #0 Thickness = 20
  2. Surf #1 Thickness = 0
  3.
Analysis Type
  1.   Operands
    1. RANG
    2. GBPS
    3. OPTH
  2.   Tool
    1. Analyze...Gaussian Beam...Paraxial Gaussian Beam
    2. Stands Spot Diagram
As a result,
RANG, OPTH, and Standard Spot Diagrams have the same values for Cases 1 and 2.
However, the result values for GBPS and Paraxial Gaussian Beam are different.
So I wonder in which case to set Surf #0 Thickness = 0.. in which case to use Surf #0 Thickness <> 0. And I'm curious about the physical difference between the two cases.
Note that, I know that GBPS outputs beam size based on paraxial rays.
Best answer by Kevin Scales
In the GBPS operand, the S1toW parameter sets the distance from the waist to Surface 1, not to the object. If you try the same process with an extra surface and swapping surfaces 1 and 2 rather than 0 and 1, you will see the difference go away. Consider Surface 1 to be the reference starting point. The help page ‘Paraxial Gaussian Beam’ has more discussion on the process that is the same one used in GBPS.
Kevin Scales
  • January 5, 2024
