Dear All,
I am attempting to replicate a Dyson spectrometer design that was reported in this paper: https://www.mdpi.com/2304-6732/9/11/865 and I tried the design you see in the attached *.zar file. I introduced a fold mirror after the slit just to fold the beam.
This the optical layout from the paper:
and this is the my optical layout I attempted:
It is a known issue that the slit position is very close to the camera position in Dyson design. However, I could see that in the optical layout reported in the paper, there is quite some space between the slit entrance and the camera. To separate the two rays, I could adjust the grating grooves (by increasing it) but it will complicate the design etc. The grating grooves reported in the paper is 13 lines/mm and I have set it to 100 lines/mm (0.1 in the lens data editor) because it just gave me a reasonable design.
My question: What could possibly went wrong in my attempt? How could I make that nice separation between the slit entrance and image plane?
Many thanks
