Hi zemaxers
I am trying to do a line scan optical system image simulation.
And the first thing I thought is multi-configuration. It makes different layouts to show as one visually, but I am wondering is it possible to show different image surfaces to show as one in sequential mode or different detectors as one in non-sequential mode? I checked the zemax help but did not find the solution.
Could you kindly give me some advice on it ?
Thanks
Yang
