How to generate a resolution target object on a curved surface?
  • September 27, 2023
  • 287 views
Mike.Jones
I would like to perform image simulation by first generating a USAF 1951 3-bar target on a curved object surface concave toward the entrance pupil, rather than on a flat surface object.  Has anyone tried that before?  How to do it?
Thanks, Mike
Best answer by Jeff.Wilde
I just put a radius of curvature on the object surface.  Now the field points have a z-component given by the sag of the object surface.
  • 510 replies
  • September 28, 2023
This post may be of some help:
When using a paraxial lens for imaging, the curved object surface produces field-dependent defocus as well as distortion.
Not sure if you want to apply correcting pre-distortion…
Mike.Jones
  • 115 replies
Thanks Jeff, but how did you apply the USAF target pattern on a curved object?  That’s what I’m asking.
  • 510 replies
