Extending optical surface outward to an outer boundary
  • September 4, 2023
  • 51 views
o.sonmez
Hi everyone,
I am trying to generate a surface starting with the boundaries of the red region to extend up to the outer boundaries shown in white color (as shown on above picture)
* My goal is to perform this without exiting the Zemax software.
* I have some constraints while extending the surface from inner boundaries up to the outer boundaries; the extension surface must be continuous and good to have no change of sign of rate of change (as shown on below picture)
Right picture has unwanted extended surface form, left picture has appropriate extended form.
 Any comment or suggestion is welcomed.
