No polarization change at metallic mirror / Reference frame of polarization pupil map?
  • August 10, 2023
  • 200 views
Johannes
I have a question regarding the behaviour of polarized rays at metallic (MIRROR) interfaces, in my case the coating is SILVER. I go in with diagonally polarized rays (from below in the image, propagating in positive z-direction).
The polarization before the rays hit the mirror look like this
Now I WOULD expect, based on the Fresnel equations for the reflection coefficients rho_p and rho_s that for a silver mirror at 45° with complex refractive index n_2 = 0.18 + 6.2*j that the reflection causes a phase difference between the two components of about 190°. That would mean that the polarization would change from diagonal to roughly antidiagonal (a bit elliptical along the antidiagonal direction.
However, I do not observe this, the polarization stays roughly diagonal (with an elliptical part).
Do I missunderstand the reference frame of the polarization pupil map in zemax? Does zemax change the direction in which it looks onto the rays somehow, such that diagonal and antidiagonal become exchanged? Or am I getting the physics wrong?
Thank you very much in advance!
Best answer by Kevin Scales
When you reflect from a mirror, remember that you are switching signs on the thickness values. The Polarization Pupil map continues looking along the Z axis towards the ray, so in the -Z direction to get X on the right and Y at the top. This means that the vantage point toggles between looking into the beam and looking along the beam each time you have a reflection.
Kevin Scales
  • 185 replies
  • August 22, 2023
