Hi everyone
I’ve been using the sequential side of Zemax for the past year, and am now starting to get into the NSQ side. I am trying to use the NSQ optimization to figure out the ROC of a lens that collimates the light for a very simple system seen below. I looked up NSDD, and am also using pre-made optimization methods from the optimization wizard (seen in the merit fx editor). However, when I press the optimization button, it gives me an initial MF of 0, even though clearly my light rays are not collimated after passing through the lens. I’ve tried to read the manual however, nothing I’ve found expalins why this is failing, or rateher, giving the wrong value. What is wrong with my approach?
