How to use coating Tapers?
  • June 13, 2023
  • 132 views
William Oak
I’m currently trying to model a thin-film based fizeau wedge, and I thought using a coating taper might be a decent way. However, I’ve found only one example of tapers being used (the coating file), and very limited information in the help.
Does anyone have some experience with how tapers work? Or some examples? My own attempts at finding additional information has been unsuccessful.
Best answer by Andrew_Davies
You can try reading the “The TAPR Data Section” of the help file.
Andrew_Davies
