I’m trying to simulate the movement of a laser beam by tilting an element (e.g. a mirror). I’d like to see the movement of the beam on the target with a physical simulation where diffraction is considered (like the image shown below).
I tried to use FFT PSF, POP and Extended Diffraction Image Analysis. However, none of these show the beam movement while tilting the mirror.
I wonder what would be a proper tool, or how I can set up these tools to achieve this task?
Sean
