Answer
CAD lens
  • March 3, 2023
  • 108 views
Christabelle Tiong
Need help!
How can I define the shape/size and dimension for lens in NSC Zemax? For instance, I would like
a rectangular lens with the side slanted with small angles.
Can it be done by importing CAD, then I define it as lens?
Hi Christabelle,
I suggest having a look at this article:
https://support.zemax.com/hc/en-us/articles/1500005487401-Improving-non-sequential-ray-tracing-speeds-with-nested-and-Boolean-objects
You can of course create a CAD and import it. But it will be slower than if you were using native objects. And when I say slower, I’m referring to the raytracing process.
I’m not sure I understood what you wanted properly, but here’s an example of how you could combine a Rectangular Volume and a Standard Lens object with a Boolean Native:
Rectangular Volume object
Overlaid Rectangular Volume and Standard Lens objects
Boolean Native object performing the intersection between the Standard Lens and Rectangular Volume objects
I’m attaching this example to my reply.
  • March 3, 2023
Hi Christabelle,
