commercial lens objectives black bock files
  • February 27, 2023
  • 1010 views
Marzanna
I am using in my setup Nikon objective however, Nikon does not provide Black Box Zemax file  (as far as I know). I wonder how other Zemax users are dealing with issue like this. I cannot just take first better objective templet ( it’s almost impossible to find exact match).  I will be grateful for any tips.
Marzanna
Mike.Jones
  • 117 replies
  • February 27, 2023
Nikon will never reveal their real designs, but instead patents facsimiles of them.  Try patent searches, that's about as close as you're going to get.
  • 1159 replies
  • February 27, 2023
Hi Marzanna,
What is the lens you are trying to simulate? Patent search is one way as @Mike.Jones pointed out, but a first approximation is to simply use a paraxial lens. It can already get you a long way.
One thing to note is that Nikon is generally using a 200-mm tube lens focal length. The magnification is the ratio between the tube lens and objective lens focal length. So, if your objective is 10X (in air), its focal length is 200 / 10 = 20.0 mm. You could use a Paraxial surface with a focal length of 20.0 mm to simulate the objective at first.
If you use an immersion lens, you may want to look into this custom surface by @Jeff.Wilde:
I also attempted to make a similar model based on a paper, but couldn’t reproduce the results of said paper:
So, it isn’t conclusive yet. I hope this helps.
Marzanna
  • 28 replies
  • February 27, 2023
Thank you for your answers. The objective I am using is
with two Thorlabs lenses that make a telecentric setup
Marzanna
