When I am generating drawing for binary 2 surface ,it is showing see attachment but the re is no attachment. How can we get standard drawing for Binary 2 surface.
Drawing of Binary 2 Surface
Best answer by Ethan
Hi
Thanks for the additional information. The ISO Element Drawing tool displays only one radius and one conic constant for each element. However, in your case, the surface is much more complex, so the drawing adds “See Attachment.” It does not actually generate an attachment; instead, you must write the attachment yourself with necessary equations, maps, and parameters.
I hope this is helpful.
Ethan
