Hello everybody, for the type of product I am analyzing, I use the NSC environment where I have a LED source, an imported CAD and a detector to detect the luminance (or illuminance) of a system. In my opinion it is not necessary, in my case, to activate the "Use Polarization" flag during the analysis. Can you confirm it?
Thanks a lot.
Best answer by MichaelH
Hi Luca,
Polarization tracing in both sequential and non-sequential mode will account for both Snell’s Law ray tracing (how the ray physically travels through the system) as well as accounting for the E-Field (intensity and phase of a ray). You need polarization ray tracing if you can about:
Fresnel reflections off surfaces
Bulk absorption/internal transmission
Coherence analysis
Hi, thanks for the clear answer. The most classic case for my work is the transmission through turbid polymers exploiting the scatter effect. I suppose it is not necessary to activate the polarization.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
