Non sequential mode: Black box
  • September 23, 2022
  • 331 views
Hi all,
Thanks in advance for putting your advice to my post.
I am simulating a microscopy in sequential mode which contain a tube lens from Thorlab. The tube lens provided by Thorlab is in black box. I want to transfer my simulation design from sequential to non sequential mode. Can I do that? Is it possible to use black box in non sequential mode?
Thanks.
Best answer by Chandan.Maurya
The above-attached post may help you!
  • 62 replies
Ethan
  • 107 replies
  • November 23, 2022
Thanks, Chandan, for commenting! @sanjeev kumar.singh, did this information help you solve the challenges with your simulation?
Mubeen Mahmood Puthiyangadi
Hi all, i have a question. I have an optical system designed in Zemax non sequential and want to hide all the design specification. Since it is not possible to convert non sequential to black box, is there any  other method to do it?. The anaylsis also has to be performed in non sequential. I have read that speos has similar to black box called speos light box. So it it possible to put together the components in speos and convert it to speos light box and bring back to non sequential so that all the design specification is hidden and analysis can be done in non sequential?
