Zernike standard coefficient data extraction
kpaladiya
I developed a lens simulation that generates a zernike standard coefficient of up to 37 terms. I use MATLAB to obtain the zenike coefficient for comparison with the real system. So, should I multiply every coeffcient with wavelegth during the extraction process, or should I just extract since it is?
Because, Zemax simulation has Concave lens geometry. and when I extract zernike coeffcient and multiply with wavelengths, it become very higher values.
[Mod edit: Moved to appropriate forum (Got a question?)]
Be the first to reply!
