ray trace problem
lumieremyoung
Hi I am senior in InHa university in south Korea.
I would like to make a headlight which uses laser diode.
So I made a source rectangle with mems.
I can see the rays traced in Detector rectangle with NSC 3D Layout and Shaded model.
But when I try to analyze the ray trace,  the results are like this shown below.
And also,
detector viewer is shown like this.
How can I solve the problem?
Best answer by David
Your detector has only one pixel. The detector has detected 0.88 watts. The number of pixels is set in the non sequential component editor. I suggest changing it to something like 100x100 and perhaps to display in false color.
  • 336 replies
  • April 26, 2022
lumieremyoung
Thank you for your kind answer. It really helped me!
