I was wondering if there is a way to coherently sum POP results, for two different wavelengths, having used the POP “use polarization” option in both cases?
According to the OpticStudio user manual, page 1154, under “Use polarization” it says that “Because these 2 beams cannot be coherently summed, any complex field data for the output (i.e. real, imaginary, or phase data) will be set to zero.”
In my case I want to coherently sum the electric field information for Ex and Ey for two wavelengths. However, I am not sure if this is possible since the phase information is cleared at the end of the POP simulation when using “use polarization”.
Thank you in advance,
Yannis
