Metalens Hybrid simulation
liuwenzhao
I want to simulate the performance improvement after inserting a metalens in camera lens, similar to the result publish in Nano letters (DOI: 10.1021/acs.nanolett.8b03567).
Nano letters paper figure 5, using zemax to simulate metacorrector with microscope objective
 supporting information for Nano letters paper, using zemax “grid phase” to calculate the focal length shift and focal spot frofile
I want to calculate the focal length shift, focal spot frofile and wavefront aberration function just like this paper. In my case, the grid phase data was generated using matlab and imported to zemax. The wavefront result was improved, but other results seems unchanged. The physical optics propagation result barely changed, I am not sure about the calculation result.
original and final wavefront
original and final POP
original and final PSF
Be the first to reply!
