Inhomogeneous scatter density in the bulk material
  • June 25, 2020
  • 91 views
I would like to simulate bulk scattering in non-sequential mode. However, the density of scattering centres in my material should not be homogeneous, but should increase as a function of the bulk width x. How is this possible? Is there already a .dll I could use? Thank you for your help!
Best answer by Angel Morales
Hi Daniel,
At this time, there aren't any Bulk Scattering DLLs which support a changing particle density for a single bulk scattering object -- the closest definition we have to modeling a particle density input for bulk scattering is through the Mie Scattering DLL. However, you could potentially approximate the desired change in particle density by defining a series of volumes adjacent to each other, each with a different particle density depending on your needs. The 'resolution' in the change in particle density would depend on how many volume 'slices' you define, but this could at least be a way to start modeling your setup.
Otherwise, for a single volume object, you will need to define a DLL yourself which models a change in the particle density depending on some inputs for the DLL. As a starting point, you could take a look at the Knowledgebase article here which gives a brief discussion on what the Bulk Scattering DLL wants to take in from OpticStudio and compute for the output scatter ray. Of course, you can take a look at the .C code for some of our Bulk Scatter models at 'C:\ ... \Zemax\DLL\BulkScatter' (note: this is the default install location, so it could be different if you've changed your directory!).
Please let us know how these thoughts work out for you!
~ Angel
Angel Morales
  • June 25, 2020
Hi Daniel,
~ Angel
