Hi all,
I currently have a hemisphere CAD model as a light source in Zemax. I would like to see the angular spread of the light source. I have tried using the polar detector and surface detector to get some type of angular sensitivity, but that does not seem to work.
Thank you for your time,
Mo
Here is a screenshot of my current output. I would think that the spread should be even across the detector, but instead there are spikes and inconsistencies.
Hi @Moohilton.Soosaippillai,
Apologies for the delayed response to your question. In case it is still relevant, please see this Community topic: Is an angle of incidence report available in the Ray Database Viewer? | Zemax Community. This discussion gives some good background and approaches to analyzing incidence angle.
Ethan
