When i make Thermal to analysis the optical performance (MTF..), the value of MCSD will affect the results.
When i set the MCSD>SDIA, the thickness value of air gap will be different.
Do you know how the MCSD affect the calculation of air gap thickness?
The MCSD itself doesn’t affect the air gap spacing but actually the combination of the SDIA+CHZN.  The following article has an illustration showing the 4 different combinations of SDIA/CHZN/MCSD.
https://www.linkedin.com/pulse/monte-carlo-thermal-analysis-michael-humphreys-rghrc/?trackingId=qYxBSM4noZk9kMMmO%2BdIVg%3D%3D
