Joining string and number in Zemax Macro
  • December 9, 2019
  • 216 views
Dear all,
I am a beginner of zpl and I want to make names of files with the 'for' loop.
For example,
   file1.txt
   file2.txt
   file3.txt
   fileN.txt
Can I add a number to a string?
What shall I do to make "filename" + number(integer)  + ".txt" ?
Is there any smart method to do this?
Thanks in advance
Sean Turner
The $STR() function is what you need. I generally iterate for loops with 'i' or 'j' as the variable, so my loop would look something like this:
FOR i, 0, n, 1
FILENAME$ = "FILE" + $STR(i) + ".TXT"
NEXT
Hello all,
I am trying to save the data with different file name using Macro, but not able to save my data with a different name. Data is saving with same name. Can anyone please help?
I am using the for loop and saving the text window using the for loop
for i,1,2,1
SAVEWINDOW 2, 'E:\faheem....\Textfile name(i)
end
The text file should very with 'i' value.
Best and regards,
Faheem
