          I am getting an error when I try to import a creo file.  Not sure if it is the file or OpticStudio.
Hello Michael,
What version of CREO are you using ?
Also, to use the dynamic link, CREO must be installed on the same computer as OpticStudio. Is this the case ?
Hello Michael,
Ah OK.  I only have the Creo file, not the software installed on my laptop with Zemax.
Thanks!
