Hello Christian,
First, in order to read the Object type of an object in the NSC Editor, you need to use the NPRO() numeric macro function:
As said in the Help, in order to read string values, you have to use the $buffer() function. So for example to extract the type of the first object, you need code 0, and the lines as in the example below:
type = NPRO(1,1,0,0)objectType$ = $buffer()print 'object type: ',print objectType$
GetNSCObjectData will not work from the ZPL macro, it is for the extensions, as you may check it from the header in the Help:
Then, once you have checked the object type, you may use the SETNSCPROPERTY keyword to change the material and the coating on the object. The proper syntax is as follows:
SETNSCPROPERTY surface, object, code, face, value
For the material you need code 4, and for the Coat/Scatter properties you can use codes 5...41 as discussed in the Help. You may read more about how to use the SETNSCPROPERTY keyword in the Help file at: The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > SETNSCPROPERTY (keywords)
For further reference, please check out the knowledgebase article about how to add coatings to non-sequential objects:https://support.zemax.com/hc/en-us/articles/1500005486641-How-to-add-coatings-and-scattering-functions-to-Non-Sequential-objects
Please make sure to use the UPDATE keyword after modifying the object parameters! You may read more about this in the Help at: The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > UPDATE
Finally, to define the length of the FOR loop, you can use the NOBJ() numerical function to extract the number of objects in the NSC Editor:
If you are in pure non-sequential mode please use 1 for the surface number input:
numberOfObjects = NOBJ(1)
If you have further questions, please let us know and we will be happy to help!
Csilla
