Possible bug? Graph doesn't fully display
  • 29 replies
Below is an example image from POP. Aspect ratio 3x4. No matter what I do, I can’t seem to get the last line item “Beam Width” to be fully displayed with aspect ratio 3x4 and 3x5. But it displays for other aspect ratios. The last line at the end seems to be cut off (both on-screen and saved image) regardless of how many times I resize the window.
Same problem w/ other analysis windows as shown in 2nd figure: Spot Diagram
Therefore, this might possibly be a bug?
Best - ASuku
Be the first to reply!
