[ZOS-API - MATLAB] open files and raytrace
  • December 8, 2020
  • 166 views
Hello!
I tried to open .zmx files and raytrace them, but I got an error code:
Error: Dot indexing is not supported for variables of this type.
        normUnPolData = rayTracer.CreateNormUnpol(nRays,realRayType,nSurf);
I think that when I open another .zmx file, the 'Open Batch RayTrace' code doesn't seem to be updated.
Could you tell me how can I solve this problem?
Thanks.
  • 1140 replies
  • January 19, 2021
Hi Kim,
Could you share an example with us? I don't see the rest of your code but in the ZOS-API syntax help, the raytracing tool is often refered to as rayTrace, and not rayTracer. Is it possible you made a typo?
The correct line of code should then be:
normUnPolData = rayTrace.CreateNormUnpol(nRays,realRayType,nSurf);
