I just got v22.1 installed and it runs very slowly. Is there an issue or setting that I should be aware of?
[Edit: moved to more appropriate forum category]
Best answer by Chris.Svec
All-
I heard from ZEMAX and they suggested the following: (which worked for me)
change your Undo settings from Multi-step Disk to Single step memory. This is in the Seetings>General tab.
Chris
