Answer
Zemax CAD export tolerance
  • December 7, 2021
  • 5 replies
  • 312 views
I exported my design from Zemax OpticalStudio 21.2 as an STL file, but found that the accuracy is not satisfactory. I think the accuracy can be improved by setting a smaller tolerance in the CAD export, however, I cannot find this option despite that the Zemax help file and the article in the knowledgebase does indicate that the software has this setting. Could any of you please take a look and tell me how I can fix this? Please see the attached picture.
Thank you.
Best answer by Jeff.Wilde
Try unchecking the “Use ACIS Libraries” box in Project Preferences:
  • December 8, 2021
Chris Normanshire
For STL files the accuracy is controlled by the Angular Tolerance setting. The default for this is Low, so try setting to Medium or High to see if that produces the results you need.
  • December 8, 2021
Thanks. This works!
  • December 8, 2021
I change the CAD library, use the default tolerance 1E-4 and set the angular tolerance to high so that the result is much better.
  • December 10, 2021
Glad you got it to work!  Good luck with your project.
