How to read field data using ZPL Macro
yuan.chen
For data that require only one parameter, we can use SYPR().
To extract field data, the solution is to use the numeric functions and a loop to extract data. Here are related numeric functions.
To read the number of fields or the maximum value, you can use the below funcions to read them:
Be the first to reply!
