round edges
  • March 30, 2021
  • 106 views
I got a rectangle lens array and the edges of the lenses are sharp. I need to round edges to the radius of 0.1mm. Can I somehow round them in non-sequential OpticStudio?
I would define a single lenslet, and use the Boolean feature to sculpt the edges wanted. Then use the Array object to form the array of them, and export to STEP to create a single part.
The Part Designer would be good for this too.. It uses a script-based approach rather than doing everything in the NSCE.
