Minor Correction of Example 02 Python Code
  • May 9, 2024
  • 50 views
Liang
Hi everyone,
In sample file 「PythonStandalone_02_NSC_ray_trace.py」, I found several slight mistakes and going to share here.
First in Line 192,
    pix = 0
setting parameter pix as 0 may cause unexpected detector data of the firt pixel(Line 199). Changing pix to 1 may fix the problem.
And in Line 216,
    detectorData = zos.transpose(detectorData)
「transpose」should be function of 「numpy(np)」,this may be typing mistake.
Please confirm and I hope it helps.
@Liang
There are several issues with the example files, I think there is a plan to update those in the near future? Another thing to consider is whether you are using Pythonnet > 2.5.2:
Regarding the transpose though, ANYS have defined their own transpose in the boilerplate template:
def transpose(data):
    """Transposes a 2D list (Python3.x or greater).
    Useful for converting mutli-dimensional line series (i.e. FFT PSF)
    Parameters
    data      : Python native list (if using System.Data[,] object reshape first)
    Returns
    res       : transposed 2D list
    if type(data) is not list:
        data = list(data)
    return list(map(list, zip(*data)))
