Through Focus Spot Diagrams separated by wavelengths
  • May 8, 2025
  • 48 views
The current Through Focus Spot Diagram (TFSD) merges all wavelengths in the same plot, however it provides separation between fields. Right now I’m cloning windows and set the wavelength separate in each window.
Is it possible to have a “simple” script to have them separate by wavelengths for a single field? What could be a command for the TFSD plot then?
In principle it gives a different view to a Focal Shift.
