Answer
Question about SURP
  • November 17, 2023
  • 146 views
bdoc
I want to change the x-pos in the NSC editor. How can I do that using SURP? The NSC surface is at 13 in the lens data editor, NSC object is 8.
Please let me if you need more information.
Thanks in advance!
Best answer by bdoc
Hello David,
thank you for your answer.
This could be another solution, right?
SETNSCPOSITION 13,8,1,50  (set object 8, x position to 50mm)
Benjamin
  • November 17, 2023
Hi @bdoc
In Non-Sequential mode, you have objects in the Non-Sequential Component Editors. Therefore, you need a different range of operands, for the X Position, you have:
  • NPXV: Non-Sequential Object X Position value
  • NPXL: Non-Sequential Object X Position lesser than
  • NPXG: Non-Sequential Object X Position greater than
You will find the same operands for Y, and Z by replacing the letter X in those operands above.
The Help File provides more insights to the parameters of NPXG:
NPXG
Non-sequential object position x greater than. Surf defines the surface number of the NSC group (always 1 in pure NSC systems). Object defines the object number in the NSC group.
If Ref? is 0, the coordinates are relative to the reference object.
If Ref? is 1, the coordinates are relative to the origin of the NSC coordinate system or entry port. If Ref? is 2, then the coordinates are relative to the global coordinate reference surface.
I hope this helps.
bdoc
  • November 17, 2023
Hello David,
Benjamin
  • November 17, 2023
Hi @bdoc,
Sorry, yes absolutely for ZPL. I somehow thought about a Merit Function operand for some reason.
