Change model glass index by ZPL in NS mode
  • November 19, 2021
  • 255 views
In Non-Sequential mode, is there a way to change the refractive index value of a model glass whithin ZPL? It seems that SETNSCPROPERTY doesn’t allow this, but only to change a glass chosing from the library.
Thank you
Iari
Hi Iari,
The Model Glass is a solve. You can recognize it by the letter M it puts in the cell right to the Material parameter. Therefore, the keyword you want to use is SOLVETYPE. Now, for a NSC model glass its syntax is a bit more complex, but should be as follow:
SOLVETYPE 1, NSC_MATM_#, indx, v_d, dPgF
Replace the # character in NSC_MATM_# by your non-sequential object number. Indx is the index of refraction, v_d is the Abbe number, dPgF is what it is (the number 1 is just here for compatibility with sequential systems and should be left as it is in pure non-sequential systems).
Let me know if this works for you.
  • 1140 replies
  • November 19, 2021
Hi Iari,
