I’m currently trying to trace a large amount (~1 million) of rays with very specific output position and trace their path length it takes them to reach a detector and then output the position as well as the specific path length of that beam. Currently not using scattering, but in future, I would like to extend this to scattering as well.
My first thought was to create a loop that would create single rays, trace them, return the OPL through a Merit Function and then output in the end, but I assume that this would take forever to compute. Any idea how this would be done more efficiently? I’ve seen that batch ray trace might be an option, but I don’t know enough about it or other alternatives to evaluate correctly.
Thank you for any help!
@ma-sunde
Your intuition is correct, I also think it is a case for batch raytracing. You’ll save a lot of overhead that you’d have with the single raytrace.
@Ali H wrote a nice section about batch raytracing in the Help File to get you started, also described here:
@MichaelH made a DLL to have fast access to the ray binary data in Python/MATLAB:
https://support.zemax.com/hc/en-us/articles/1500005576882-Batch-Processing-of-Ray-Trace-Data-using-ZOS-API-in-MATLAB-or-Python
If you prototype something and encounter any issues let us know.
I’m currently using a Two Angle source in non-sequential mode but my challenge is that I didn’t find a way to find the OPL for specific rays simulated.
Looking at the RayTrace.dll I’m now wondering if i could continue to use the Two Angle source, run a non sequential ray-trace and store the zrd file for the raytrace? Using the IZRD Reader, would I be able to read the segments (and specific angular positions of each ray) and OPL from the zrd file? This would avoid using the batch raytracing if I’m not mistaken.
@ma-sunde
Indeed, the DLL is made to read ZRD files. Whether you generate them via batch raytracing in ZOSAPI or simply through the user interface shouldn’t matter. Let us know otherwise. And yes you should be able to read segment data as you expect.
EDIT: the DLL was posted in 2021, and there have been some changes in the ZRD format in between as ​@MichaelH  documented in this post:
Therefore, I’m not sure if the DLL is fully up-to-date, I’ll let you check.
As ​@David.Nguyen mentioned, the ZRD format has changed and the DLL is not updated.  However, the new format makes calculating the full OPL extremely easy (even for GRIN materials).  There are 2 new OPL fields in the ZRD file for each segment: OPL_waves and OPL_lensunits.  If you simply cycle through all the segments and add all the OPLs for the given ray, you’ll get what you’re looking for.  If you have Ray Splitting turned on, make sure to be careful to match the Parent and Child segments properly.
