I would like to design 16 Fresnel lens in non-sequential mode. How to design array structure? Can anyone give solution.
How to design Fresnel lens array(4*4) in Non-sequential mode?
Best answer by Kevin Scales
To elaborate on Mark’s answer, using an Array object will look something like this example, where there is a parent object, the Fresnel lens, and an Array object that specifies the parent, the number of array elements in X, Y, and Z, the spacings, and so on. There is a lot of versatility. If you want a circular array, the Array Ring object is also available.
