How to setup Visual Studio Code (or other open source IDE) to compile a DLL for Zemax
  • August 24, 2020
  • 639 views
Michele.conni
As stated in the title I need to compile my own DLLs for my system.
I don't have access to Visual studio or Visual Studio community, and in general, I try to work as much as possible with open source solutions.
Can somebody help me to set up an environment to compile a DLL with free and open source IDE and compiler? Ideally Visual Studio Code.
I'm working on Windows 10 x64.
Hi Michele,
We have an article that explains how to compile a DLL with Visual Studio: How to compile a User-Defined DLL.
When compiling with a different compiler, it shouldn't be much different so the instructions are still relevant. The main point is to use a 64bit compiler. For example, I did a private training where we used Dev-CPP.
Let us know if you need help on a specific point.
Sandrine
Hi Michele,
Sandrine
