DLL (Source): Non-sequential Hermite-Gauss
  • October 3, 2023
  • 229 views
  • Visible
  • 22 replies
This Source DLL models an Hermite-Gaussian Source using ray generated at position and angles following the intensity of the electric field and the angular spectrum.
This Source DLL is inspired by the known DLL (Source): Non-sequential Astigmatic Gaussian
DLL (Source): Hermite-Gauss take 4 parameters:
  • w0_x, w0_y are the theoretical beam waist of the fundamental mode
  • n_x, m_y are the mode indices in the corresponding directions
Authors:
Oran Meir - TriEye
@Eyal Hollander- TriEye
References:
1. Goodman, J. W. (1996, January 1). Introduction to Fourier Optics. McGraw-Hill Science, Engineering & Mathematics, Ch 3.10
2. Carter, W. H. (1980, April 1). Spot size and divergence for Hermite Gaussian beams of any order. Applied Optics, 19(7), 1027. https://doi.org/10.1364/ao.19.001027
3. Gaussian beam. (2023, September 3). Wikipedia. https://en.wikipedia.org/wiki/Gaussian_beam
4. Fourier transform. (2023, September 27). Wikipedia. https://en.wikipedia.org/wiki/Fourier_transform
5. DLL (Source): Non-sequential Astigmatic Gaussian | Zemax Community. (n.d.). https://community.zemax.com/code-exchange-10/dll-source-non-sequential-astigmatic-gaussian-1695
02/10/2023 1.0 2022 R2.01 Creation
  • 1159 replies
  • October 4, 2023
Hi @Oran,
That looks awesome. I don’t see a link to download your code though, is that normal? I was curious to know how you implemented the random ray generation. Did you use rejection sampling?
  • Visible
  • 22 replies
  • October 5, 2023
Hi @Oran,
Hi David,
Thanks for letting me know about the download, it must have been dropped in one of my edits. You may see the file attached above.
And yes, for the random ray generation I used rejection sampling as you correctly guessed.
Oran
