An introduction to interfacing to OpticStudio from Mathematica 1_1
  • June 26, 2022
  • 146 views
Attached please find several files in a zip folder. The primary file is a Mathematica notebook initially intended as a knowledge base article.  It could also be a post in the Code Exchange forum. I have included a draft readme file in case you feel that is the best use. If you think it’s worth sharing, please use it as you think best.
Please feel free to request edits.
The files in the folder are:
   The notebook: “An introduction to interfacing to OpticStudio from Mathematica 1_1.nb”
   A PDF of the same: ” An introduction to interfacing to OpticStudio from Mathematica 1_1.pdf”
   The readme draft: “ReadMe.docx”
Thank you David. This is brilliant! We’ll have a look.
Hi David! I hope you are well. I finally come around to this. Sorry about that. Would you have a word version of the pdf by any chance? No worries if not.
  • 337 replies
  • July 29, 2022
Hi Sandrine.  No worries. I sent you an email about this.
